Nutanix Move Can't migrate vm (SQL) in vmware it show PCIE pass-through not support only 1 Server.
Thank you for answer.
Best answer by Alona
Please note that a recommended way to migrate SQL servers would be to install a new SQL Server, and then perform the migration operations.
That being said is there a PCIE passthrough configured on the VM? If it is, then it makes sense that a VM can’t be migrated since it has a physical device presented to it.
Let me know if the above makes sense please.
