Installation failure: fatal Running CVM installer | Nutanix Community
  • October 9, 2019
  • 2012 views
I'm trying to install a 3-node Lenovo HX3321 but I got this issue:
Every node gets the following log:
It keeps waiting for md arrays to resync but it no longer continues the process and fails.
I'm trying to install AOS 5.10.6 and foundation 4.4.1
Do you have any idea how I could fix this issue?
Best answer by Roberto_MX
Just for your information:
We’ve solved this issue from command line. We assigned IP addresses to IPMI ports and CVMs before to create Nutanix Cluster by “cluster create” and “ “cluster start” commands.
  • November 4, 2019
