Need help setting up Virtual Private Clouds | Nutanix Community
  • August 30, 2019
  • 1355 views
If I have 3 Nutanix nodes and I cluster them together. How can I make a separate VPC for a test stack and a separate VPC for a Production stack? So that way I can build my VM's on the test stack and once they are good to go...I can do the same steps on my Production stack. I would like to have 2 isolated stacks for testing and production.
Is this possible?
Best answer by danny_sre
Hi Nyth,
Reviewing your requirements for separate stacks, if this is to separate Dev / Prod but wish for them to continue to share resources then were talking about a logical separation via network segmentation:
https://portal.nutanix.com/#/page/kbs/details?targetId=kA00e000000CruqCAC
Please review and let us know if you have any additional questions.
DannyR
danny_sre
  • 13 replies
  • November 25, 2019
Hi Nyth,
DannyR
