IF an admin resolves an alert but doesn't fix the condition, does the alert retrigger? and if yes, how long before it does?
Thanks in advance.
Nutanix alerts
Best answer by Shridhar
Hi @theGman
Yes,If alert is not addressed ,alert would re-trigger
Duration depends upon the alert if it's system generated alert(depends upon value or interval at which it triggers or event driven )
For more info refer to following thread
https://portal.nutanix.com/#/page/docs/details?targetId=Prism-Central-Guide-Prism-v511:mul-alerts-management-pc-c.html
Hope it helps!!
View originalYes,If alert is not addressed ,alert would re-trigger
Hope it helps!!
