Need help with Health Check results | Nutanix Community
Hey guys,
After an installation on customer site, I got this message in the Health Check.
INFO: Cluster does not satisfy the pre-requisite for enabling deduplication
I can't find a description for that message online.
Can someone help me with that?
Cheers
Dennis
Best answer by RichardsonPorto
Hi @DennisFFM
Can you check if you configured the CVM with memory that satisfy the requirements for deduplication? You can find the requirements here: https://portal.nutanix.com/#/page/docs/details?targetId=Web-Console-Guide-Prism-v510:sto-dedup-recommend-c.html
RichardsonPorto
Hi @DennisFFM
  • July 17, 2019
Hi @RichardsonPorto
That's the solution.
Thank you so much!
Didn't think about the CVM memory and was wondering why 1TB of RAM in the cluster doesn't satisfy the requirements for deduplication... 🤔😂
Have a nice day!
Dennis
