I wanted to clarify if Xtract is just for converting from ESXi / Hyper-V /AWS to AHV or if ESXi to ESXi conversions are suppported with Xtract 2.0 / Move 3.0. We have about 100 VMs we'd like to move from one ESXi cluster to another ESXi cluster and I know we could use VM Converter or cross cluster vMotions (where supported) but wanted to see if the native Nutanix tools are also an option for this type of migration.
I had thought it was mainly for migrations to AHV, has that changed?
Possible to V2V from ESXi to ESXi on Nutanix HW with Xtract/Move?
Best answer by RichardsonPorto
Hi @McCranium
If source and destination ESXi cluster are running on top of Nutanix, you can use AsyncDR to migrate VMs from one cluster to another. Just create a protection domain on source cluster with VMs that you want to migrate and after the replicate it, perform the failover. For more information about AsyncDR, check the following documentation: https://portal.nutanix.com/#/page/docs/details?targetId=Web-Console-Guide-Prism-v510:wc-dr-management-wc-c.html
View originalIf source and destination ESXi cluster are running on top of Nutanix, you can use AsyncDR to migrate VMs from one cluster to another. Just create a protection domain on source cluster with VMs that you want to migrate and after the replicate it, perform the failover. For more information about AsyncDR, check the following documentation: https://portal.nutanix.com/#/page/docs/details?targetId=Web-Console-Guide-Prism-v510:wc-dr-management-wc-c.html
