https://portal.nutanix.com/#/page/docs/details?targetId=Web-Console-Guide-Prism-v510:wc-network-visualizer-supported-switches-r.html
LLDP is enabled globally on the 9K, and I can populate the 9K switch info into Prism just fine. The issue is I can't get any port data. Nutanix Support is saying the issue is by default the "port-id-subtype" is set "locally-assigned", and it needs to be changed to "interface-name". The 9Ks are in ACI-Mode, not NX-OS, and no one seems to know how or where the change is made. Has anyone gotten this setup to work? Here are some pics from my environment. Thanks!
Hi, did you ever get this sorted? We’re having the same issue, displays perfectly on our DR site (with 5K’s), no port details on the 9K’s on our primary site.
To the best of my knowledge, this was fixed in AOS 5.5. Could you please confirm the version of the affected site?
I have now got it displaying correctly by switching to SNMPv2 - problem exists if we try and use SNMPv3.
