CVM Swap and Partitions details | Nutanix Community
  • May 17, 2019
  • 845 views
CVM Swap and Partitions details.
What are the partition used for metadeta.
  • November 25, 2019
Hi Akshay,
CVM OS resides on SSD, below is how it is partitioned
You can use “df -h” or ‘lsblk’ command to view your partition, refer the attachment to differentiate between single and dual SSD.
Thanks!!
Priyanka
