X-Ray - 504 Error Gateway Timeout when exporting Test Results
Does anyone know of a way to adjust the Gateway Timeout setting?
Best answer by Roberteo
Sorry for taking so long to get back to you. Yes, this is still happening but we have come up with a work around. The solution was to reduce the number of tests per 'round'. At this point, we perform a round of testing then circle back to re-run any failed tests. We then export the tests and delete them from X-Ray. The issue seems to be that too many test results (or maybe analysis) results in the error.
