Windows Virtual Disk locked | Nutanix Community
  • February 1, 2019
  • 6 replies
  • 546 views
I have windows 2012 r2 VM but I forget the windows administrator password.
When I'm trying to reset the password from recovery command line using below command.
  1. X:\sources
  2. d: cd windows\system32\ren utilman.exe utilman.exe.old
  3. copy windows\system32\cmd.exe utilman.exe.
Usually above command will work for normal physical windows server , ESXi Guest vm's to reset the local administrator password.
** In nutanix recovery command line I am unable to view my actual OS disk.
Is there any way, How can i view my guest VM os disk on recovery mode. ?
Best answer by Jegan S
@ jrack
that also will not work.
I have changed bus type from SCSI to SATA then I tried to reset the password. It's working now.
  • February 1, 2019
Hi team, i am also facing same issue.Please help me guys.
Forum|alt.badge.img+25
  • 291 replies
  • February 1, 2019
Guessing you need to add the virtio drivers. Mount the iso and use pnputil I think
  • February 1, 2019
@ jrack
  • February 1, 2019
Only SCSI virtual disk's are not showing. I have changed the virtual disk bus type to SATA & tried.
  • 291 replies
  • February 1, 2019
Yup SATA drivers are native, but virtio SCSI drivers are not.
  • February 1, 2019
I agree.
for time being i have given the solution. do you any idea ? what's the permanent solutions for this ?
