DELETE cluster/nfs_whitelist/{name:.+} | Nutanix Community
  • January 21, 2019
  • 1676 views
I have been trying to remove an existing nfs whitelisted machine through Rest API explorer.
API: cluster/nfs_whitelist/{name:.+}
I have tried giving the path parameter with different combination of IP/sunbnet mask but all were failed with
error message: Specified NFS Whitelist does not exist. Here, machine IP is whitelisted as I can see it in Filesystem whitelists but
I am not able to figure out the exact representation of path parameter. If anyone knows, then please tell me.
Thanks in advance.
Best answer by sandeepmp
@Pawan_sahu
You can try below.
  1. Request URL: https://Server_ip:9440/PrismGateway/services/rest/v1/cluster/nfs_whitelist/remove_list
  2. Request Method: POST
  3. Body : ["Ip/subnet"]
sandeepmp
Forum|alt.badge.img+19
  • 64 replies
  • January 21, 2019
@Pawan_sahu
You can try below.
  • January 21, 2019
Thanks for help. This is working for me. But it gives Http status 200 for any IP(whether it is whitelisted or not).
