Nested HyperV on AHV | Nutanix Community
  • December 6, 2018
  • 1909 views
Has anyone successfully been able to get HyperV(or ESXi) nested under AHV? I do see nested KVM VM's are supported but no mention of anything else.
Only reason for exploring this is to get Cisco Umbrella VA's working under AHV so i don't have to re-purpose an old server to run HyperV/ESXi.
Forum|alt.badge.img+17
  • Outrider
  • 62 replies
  • December 11, 2018
AHV is developed based on KVM so basically I think there would be no difference between nested KVM and nested AHV. You should give it a try anyway.
  • 20 replies
  • January 4, 2019
@petep if you try this, please update us as I'm curious as well.
flhoest
Forum|alt.badge.img+16
  • 25 replies
  • March 1, 2019
I am also very curious, I'm actually trying this now ... without luck so far.
  • May 28, 2019
@petep Any luck with getting the Umbrella VA’s working ? Just ran across someone else who will need to do that as well...
  • May 28, 2019
The latest version of the Umbrella appliance now works on AHV.
I still had my old esxi environment up so i deployed there and then migrated over just in case but don't see why importing the vmdk's wouldn't work.
good luck!
