Encountering below error when configuring hyper-v cluster on Nutanix AOS 5.5.0.5
An error occurred while performing the operation
Could not logon as the specified user 1385
Error configuring Hyper-V cluster
Best answer by bezeddin
have you check this link
make sure you use domain account with local admin rights
View originalmake sure you use domain account with local admin rights
