"download and deploy prism central" neverending task | Nutanix Community
  • February 9, 2018
  • 1516 views
I tried to install Prism Central, the task named "download and deploy prism central" is now 100% since three days and i cannot stop it through PRISM interface.
I have seen that ncli has a "task" command, but looks like not useful. I have been trying to find the task with "progress-monitor" command, but it shows nothing related to prism central.
How can I stop it? Or at least clean the task to proceed with a new installation?
Best answer by sandeepmp
@iancafdfds You can find the task under "acli".
If you still have the issue, can you contact nutanix support with a case and we will help to clear the task.
sandeepmp
Forum|alt.badge.img+19
  • 64 replies
  • March 13, 2018
aluciani
Forum|alt.badge.img+34
  • Chevalier
  • 348 replies
  • March 13, 2018
Hi @iancafdfds
Did the reply from @sandeepmp help? If yes, consider clicking the 'Best Answer' link - that will help others on the community find answer to the same question more quickly. Thanks
