Prism Central - New Scenario | Nutanix Community
  • November 28, 2017
  • 6 replies
  • 2185 views
we installed last week the latest version of Prism Central (5.1.3), when we tried to add a New Workload into new scenario, based on "Existing VMs" we have always the following error: "RPC error kTransportError raised"
If I add an SQL Server as Wordload, Prism Central works fine.
Br,
Emanuele
Best answer by emyratti
Hi Harryhy,
thanks for your replay, we resolved the issue: we upgrade the PC at 5.5 version and the PC works fine. We can create a new scenario based on existing VMs.
BR,
Emanuele
aluciani
Forum|alt.badge.img+34
  • Chevalier
  • 348 replies
  • November 29, 2017
Thanks for the post emyratti
Anything you can add here hyang ?
Forum|alt.badge.img+11
  • 30 replies
  • November 29, 2017
Hi emyratti,
Sorry to hear that you hit a problem while using the just-in-time forecast feature. It is a known bug. It is fixed in NCC 3.5. It will be released very soon with our Prism Central 5.5. It is worth noting that, once it is released, to take this fix, you don't need to upgrade to PC 5.5 (although we recommend you to do since it brings many new features, e.g. anomaly detection, inefficiency detection, reporting, etc.). You can just upgrade your NCC to NCC 3.5 and maintain your current version.
Harry
aluciani
  • Chevalier
  • 348 replies
  • November 30, 2017
Hi emyratti
If you find a reply that helps be sure to click the 'Kudo' button to let the author know you appreciate the answer and also click the 'Accept as Solution' button so others in the community can find answer more quickly.
  • January 8, 2018
I upgraded the NCC to 3.5 version but we have the same issue.
Emanuele
  • 30 replies
  • January 8, 2018
Hi Emanuele,
Can you file a support ticket with us?
  • January 9, 2018
Hi Harryhy,
BR,
Emanuele
