Nutanix CVM to Internet Firewall Exception | Nutanix Community
  • November 12, 2017
  • 1864 views
cshakeer
Hello Guys ,
We are running CVM on intenet restrcited Vlan , May I know if I have to give any exception for nutanix update server , ntp..etc
Here are the few traffics being blocked by my firewall.
206.169.130.226 Port 443 ( CVM to Internet )
Best answer by sandeepmp
cshakeer
Please refer below docs.
https://portal.nutanix.com/#/page/docs/details?targetId=Advanced-Admin-AOS-v52:app-port-requirements-r.html
https://portal.nutanix.com/#/page/kbs/details?targetId=kA0600000008dQcCAI
https://portal.nutanix.com/#/page/kbs/details?targetId=kA0600000008Wz4CAE
sandeepmp
Forum|alt.badge.img+19
  • 64 replies
  • November 12, 2017
sandeepmp
  • 64 replies
  • November 14, 2017
cshakeerHow are you?Hope we were able to answer your queries.If so, please mark the post as resolved
  • March 30, 2018
Hi I have issue with security team.
They need to block port 2100 but , genesis require port 2100. I read may document I found this port use for AFS. And I didn't use AFS. Can I block this port ?
  • May 3, 2018
Hi all,
We see that PrismCentral is trying to contact the exact same IP (206.169.130.226) on port 443 all 5-20 seconds. Also the PrismElements contact this IP but not that often. I do not see this specifiy IP in the linked KB article, so for what reason do they try to connect this specifiy IP so often?
KR & thanks,
Lukas
