Export/Import & Backup Prism Central / Element Configuration | Nutanix Community
  • January 26, 2017
  • 2736 views
Is there a way to export/import/backup configuration of Prism Central / Element?
Best answer by harryhy
It is currently not supported. Engineering is looking for a way to do it. The timeline is TBD.
Forum|alt.badge.img+11
  • 30 replies
  • January 26, 2017
  • 6 replies
  • January 26, 2017
Thanks! Keep us posted 🙂
