How do you stop a task that is running (such as a remote site creation). | Nutanix Community
  • November 18, 2015
  • 4527 views
Can anyone help me find a way to stop the creation of a remote site.
I was told it would take around 10-15 minutes, but so far after 3 hours it is still running at 0%!
There is probably some configuration issues on the network, so I would like to fix that up first and try again.
For the life of me, however, I cannot find how to stop the task.
Nick
Best answer by brisnick
Hi ,
All I can do is clear the message.
In the end it timed out, but we've had a few goes with Data Protection (to both Azure and AWS) and it always eventually fails (SSH fails quicker than VPN) even though it appears to set up the correct environment in the cloud (the CVM/Storage/Cloud Service, etc.)
Would be nice to be able to cancel it though.
Nick
dlink7
Forum|alt.badge.img+19
  • Moderator
  • 107 replies
  • November 19, 2015
Hey Nick
Are you able just to canel the task on the blue status happening in prism?
-DL
  • November 20, 2015
Hi ,
Nick
Jon
Forum|alt.badge.img+29
  • 569 replies
  • November 20, 2015
Hey , this is another issue that we'd invite you to bring up with Dell support, who can get Nutanix support engaged as need be. We'd be happy to help walk you through power through the issues you're having with setting up data protection to cloud.
