Cluster create fails | Nutanix Community
  • January 29, 2015
  • 10173 views
hi,
i am trying to create a cluster manually.
3 cvms, all pinging each other, ssh to each other OK, network access OK
nutanix@NTNX-xxx-B-CVM:xxx:~$ cluster -s a,b,c create2015-01-29 02:34:48 INFO cluster:1663 Executing action create on SVMs a,b,c2015-01-29 02:34:48 WARNING genesis_utils.py:325 Failed to reach a node where Genesis is up. Retrying... (Hit Ctrl-C to abort)2015-01-29 02:34:49 WARNING genesis_utils.py:325 Failed to reach a node where Genesis is up. Retrying... (Hit Ctrl-C to abort)2015-01-29 02:34:50 WARNING genesis_utils.py:325 Failed to reach a node where Genesis is up. Retrying... (Hit Ctrl-C to abort)2015-01-29 02:34:51 WARNING genesis_utils.py:325 Failed to reach a node where Genesis is up. Retrying... (Hit Ctrl-C to abort)2015-01-29 02:34:52 WARNING genesis_utils.py:325 Failed to reach a node where Genesis is up. Retrying... (Hit Ctrl-C to abort
esxi 5.5 u2
nos 4.0.2.2
I ve done a lot of install of 4.0.2.2, first time I see this error.
vinny
Best answer by cbadami
Hi Vinny,
Please run the below commands:
# cluster start all
If the above command does not work, try the below on all nodes in the cluster individually:
# genesis start
OR
# genesis restart
Then try running the below command from one of the nodes:
# cluster start all
Please let me know if that helps.
Forum|alt.badge.img+14
  • 25 replies
  • February 2, 2015
Hi Vinny,
# cluster start all
# genesis start
OR
# genesis restart
# cluster start all
  • February 3, 2015
Genesis should be started on the nodes in order to create the cluster. You'll want to determine what is in the genesis.out file to see why genesis is not starting. From that CVM, cd to ~/data/logs and enter 'tail -f genesis.out'. Once you have the messages in that log, post to here and we can take a look. That log will constantly overwrite itself as genesis crashes and tries to restart; the tail -f will allow messages to scroll on the console.
  • February 4, 2015
thanks men,
a restart of genesis solved the issue,
vinny
  • June 20, 2018
nutanix@NTNX-d0d628b0-A-CVM:172.20.1.221:~/data/logs$ tail -f genesis.out
2018-06-20 08:01:01 INFO ipv4config.py:809 Netmask is 255.255.255.0
2018-06-20 08:01:01 INFO ipv4config.py:843 Discovered network information: hwaddr 50:6b:8d:b4:f2:09, address 172.20.1.221, netmask 255.255.255.0, gateway 172.20.1.254, vlan None
2018-06-20 08:01:01 INFO node_manager.py:4693 Svm has configured ip 172.20.1.221 and device eth0 has ip 172.20.1.221
2018-06-20 08:01:01 INFO node_manager.py:6326 No cached Zeus configuration found.
2018-06-20 08:01:01 WARNING node_manager.py:6275 /home/nutanix/data/zookeeper_monitor/zk_server_config_file could not be opened
2018-06-20 08:01:32 ERROR ipv4config.py:1595 Unable to get the KVM device configuration, ret 1, stdout , stderr br0-backplane: error fetching interface information: Device not found
2018-06-20 08:01:32 INFO node_manager.py:4798 Could not discover the hypervisor backplane IP configuration
I got this error while checking genesis details. someone could help ?
