Can anyone provide suggestion/feedback on creating Nutanix Deployment Checklist?
do you mean for a nutanix cluster or any specific nutanix product?
Yes, that’s correct. I am looking for Nutanix Cluster which include it’s required components.
If you work for a nutanix partner you have access to the service delivery kits. There are all the checklists you want.
You need access here: https://partnerportal.nutanix.com/
But if you don't work for a partner you will not be granted access.
Yes,
Login to the partner portal go to Sell → Service Delivery Kits → NCI → all downloads ;)
Please suggest which certificate i need to achieve?
Though I have completed NCP-5 but few years back and seems it’s expired now. Please suggest
Here is the certification/training: https://university.nutanix.com/learningpath/overview?learningPathId=65002fb3ca64f2517ec96621
You will learn how to use the SDKs in that training as well.
