Is it possible to deploy a Witness VM for Metro Availability at the disaster recovery (DR) site? | Nutanix Community
  • March 9, 2025
  • 32 views
If I have two AHV clusters distributed across a primary site and a disaster recovery (DR) site, and I configure Metro Availability between them, is it possible to deploy the Witness VM at the DR site?
Best answer by ahmad.jamali
is it possible, yes, is it recommended, no.
the witness VM should be on a separate fault domain (not in site A , nor site B)
