Right after I accpet the EULA the screen is terminating with this error “QEMU limits the disk serial length to 36, Serial is found duplicate after truncation XY”. Now I can’t find anything on the web related to this problem, so I’m going to ask it. What does this error mean and how could solve it? I’m using the CE version 2.1
Problem Solved. Turns out it was the RAID Controller inside my hp proliant 380! I had to set it to HBA (pass-through) Mode and then it worked like fine wine. I hope this helps anybody. Took me me and my friend a while to solve it.
This is a bit better written: https://next.nutanix.com/discussion-forum-14/nutanix-ce-installation-with-p420i-raid-43400
