Unlock function ‘Multiple Site DR" for many-to-many | Nutanix Community
  • November 20, 2024
  • 67 views
Currently, I have a Nutanix Acropolis PRO (P1.0) license where the ‘Multiple Site DR’ feature is limited. By upgrading the license to P2.0, if I understand correctly, this feature should be unlocked, enabling the possibility of having Multiple Site DR as many-to-many. Is this correct?”
Is there anything else you need help with regarding this upgrade?
Thank you for your help
Best answer by Stephen Smith
Hey Simons283,
Thank you for your patience while we looked into your question.  🙂
We found that even with the NCI Pro licenses, the Advanced Replication add-on license will still be required to enable the Multi site DR feature.
Our documentation team will be updating the website to reflect this.
Thank you for the catch.   🤓
Let me know if you have further questions on this.
-SS
Stephen Smith
  • 12 replies
  • November 20, 2024
Hey Simons283, this is a great question.
I am verifying the entitlement piece and will get back to you but the documentation I found on the Nutanix website supports your theory.
Regarding the conversion itself, your Nutanix account team really should be brought in to consult the details around the conversion as they understand the process and the long term end results you will be looking for in your environment.
Some items to keep in mind for using the latest licensing model.
  After the conversion to the new licensing model, the licenses will need to be applied through Prism Central.   This simplifies the licensing process especially for larger environments so you are not having to visit every Prism Element cluster registered to PC.
The other piece is just to verify you have at least the minimum software levels on your clusters as detailed in the article below.
  Article link
If you need assistance with deploying Prism Central or have any questions for the support teams, feel free to open a support case and we can get you taken care of.
Support portal
-SS
  • November 21, 2024
Hi Stephen,
Thank you very much for your support.
Stephen Smith
  • 12 replies
  • December 3, 2024
Hey Simons283,
-SS
  • December 4, 2024
Hi Stephen,
Thanks for your support.
LS
