aos 6.5.5.7
prism central :2022.6.0.10
karbon version 2. 2. 3.
I enabled karbon,I failed to upgrade karbon using lcm with the following error message: 2024-08-31 17:03:20,326Z ERROR 46603952 helper.py:145 (192.168.30.28, update, aff9f64a-6e19-41a4-5fda-68e7f423c861) 2024-08-31 10:03:20.231345 EXCEPT:{"err_msg":"
Update failed with error: rFailed to initialize precheck helper: Failed to initialize Nutanix Kubernetes Engine interface: Failed to build Nutanix Kubernetes Engin
e session: Failed to get auth session cookie: Failed to make GET request: URL: https://192.168.30.28:9440/api/nutanix/v3/users/me, the error: HTTPSConnectionPool (host =
'192.168.30.28', port=9440): Read timed out. (read timeout=30)]", "name": "relea.karbon.update ", "stage": 0}
I executed the karbon login command successfully, but karbonctl airgap list failed
nutanix@NTNX-192-168-30-28-A-PCVM:~/data/logs$ /home/nutanix/karbon/karbonctl login --pc-username admin
Please enter the password for the PC user: admin
Login successful
nutanix@NTNX-192-168-30-28-A-PCVM:~/data/logs$ /home/nutanix/karbon/karbonctl airgap list
Failed to list airgap:  Post "https://127.0.0.1:9440/karbon/acs/airgap/list": context deadline exceeded
Can someone help me!
Be the first to reply!
