I’m trying to retrieve all VM and CVM using the following endpoint in PowerShell
https://example.com:9440/api/nutanix/v3/vms/list
I get all VM information back as requested but unfortunately I’m not getting any CVM and there is no information related to this in the offial API documentation.
As far as I understand in version 1 you would get all vms and cvms using same endopint (vm/list)
Is there something I’m missing to set up in order to get the controller vitrual machines ?
    "kind"  = "vm"
    "length" =  50000
    "offset" =  0
What user are you using for the requests.  Try doing the request with the Admin user, as I believe they’re filtered out for non-admin users.
Also, you could try passing a filter that reads: include_cvms=true.   Worth a try...
I just got the admin role but I got the same result.
I found out it has something to do with API versioning, I don’t think there is no way to get thos objects though.
https://next.nutanix.com/how-it-works-22/unable-to-retrieve-cvm-from-v2-v3-api-39756?sort=dateline.desc#comments
