While making a rest call to update an endpoint, I am getting below error.
    "api_version": "3.1",
    "code": 500,
    "message_list": i
            "details": {},
            "message": "uuid",
            "reason": "INTERNAL_ERROR"
    "state": "ERROR"
Steps performed:
  1. Make a get call to the resource UUID
  2. Remove the status key blog from the body received from step 1
  3. update the value key with new IP
  4. update the spec_version from current set of 0 to 1
  5. use this updated body to make PUT call to the resource UUID
Be the first to reply!
