We have just implemented a pairing with a customer on-prem cluster and a protected side cluster and created some protections domains.
All seems to works well but we search to obtain more information on protected side.
We are currently unable to view Entity Count, Next Snapshot Time, or Entities on a selected Data Protection.
Is there a way to obtain this informations ? Is there anything thats was badly configured ?
Thanks for your help ;)
HI, lleuba86,
Can please advise if you are using Protection Domains from Prism Element or Leap from Prism Central?
F>P
Hi sl.farhanparkar, thanks for your return.
I use Protection Domains from Prism Element.
Regards
