I just created a new cluster but there is no default virtual switch created (vs0).
Is this something expected ?
Ventura
Unfortunately any typo in the title can’t be fixed; should be:
“New cluster but no virtual switch”
Well how did you manage to connect to your cluster then ?
did you connect to one of your CVM and run ovs-vsctl show ?
when connected to prism  → network on the top left corner what is the name written there ?
Hi MNoufel,
I think there is a misunderstand on my side.  The documentation says br0 / vs0 what suggest me the name is vs0 or br0; however, some documents says that I should have at least one default vs0 but I can’t find.
And the same from cli.
What I am missing here?
Problem fixed!
The eth1 was using an incorrect MTU value and I received an alert about that. With all using 1500 MTU everything is OK.
