i have nutanix 3060g8 i have error:
Committed memory update intent   that is stuck on 50%
i tried to reboot cvm and all nodes but i still have same problem.
cvm memory  are 64gb
i tired:
ecli task.list include_completed=no
Task UUID                             Parent Task UUID  Component  Sequence-id        Type          Status
f0ffcb92-96b1-426f-51d7-204729b269fe                    kGenesis   1        kCvmreconfig  kRunning
progress_monitor_cli --entity_id="f0ffcb92-96b1-426f-51d7-204729b269fe" --delete
any suggest ?
Hello @Amin.elzein
Upgrade the AOS to the version 5.20.3 or 6.1 or newer, which have the fix before doing a CVM memory increase.
If the memory upgrade has been already started and got stuck, please, contact Nutanix Support.
