What is the minimum number of nodes needed to configure a Replication Factor of 2 (RF2)?
3 nodes minimum for RF2
3 nodes
you can have the 2 Node cluster if workload is very small or branch office. but you can't expand the 2 node cluster.
Nutanix Support might need to engage to convert 2 node cluster to 3 node cluster. only supported 2-Node models are 1175S.
But is it RF2 if you have a 2 node cluster?
Yes, 2 node cluster will tolerate 1 node failure
