Hello everyone.
I am planning synchronous replication between two sites with AHV, and the prerequisites are not clear in the documentation. I have 960GB SSD disks on the hosts. Apparently the minimum required is 1.2TB but it's not explicit in the documentation. Does anyone know where I can validate this information?
Thanks! :)
For DR solutions with Asynchronous, NearSync, and Synchronous replication schedules to succeed, the nodes in the on-prem AZs (AZs or AZs) must have certain resources. This section provides information about the node, disk and Foundation configurations necessary to support the RPO-based recovery point frequencies.
  • The conditions and configurations provided in this section apply to Local and Remote recovery points.
  • Any node configuration with two or more SSDs, each SSD being 1.2 TB or greater capacity, supports recovery point frequency for NearSync.
  • Any node configuration that supports recovery point frequency of six (6) hours also supports AHV-based Synchronous replication schedules because a protection policy with Synchronous replication schedule takes recovery points of the protected VMs every 6 hours.
Reference: https://portal.nutanix.com/page/documents/details?targetId=Leap-Xi-Leap-Admin-Guide-v2022_6:ecd-ecdr-resource-requirements-r.html
Nutanix AHV Support 2 options:
  • Near-Sync
    • for Near-Sync atleast 1.2TB SSD is required.
    • RPO you get below 15Mins
  • Sync Rep (Metro)
    • Real Time Replication ( Zero RPO)
    • each site has its own Nutanix cluster, however the containers are “stretched” by synchronously replicating to the remote site before acknowledging writes.
    • Basically you should have enough SSD free for Sync Rep data.
Please Nutanix DR Documentation for details
