Managed Network across clusters | Nutanix Community
  • September 14, 2022
  • 7 replies
  • 164 views
Hello All,
       I have added a managed network in our cluster. We have since purchased another cluster and in the process of configuring VXLan and the ability to live migrate VM’s between clusters. From what I have been seeing we cannot have a managed network across clusters is this correct? If not does anyone know how to configure a managed network to work between clusters.
Scott
dlink7
Forum|alt.badge.img+19
  • Moderator
  • 106 replies
Today Flow virtual networking is not supported on AWS
  • 20 replies
This is really unfortunate. I appreciate your timely reply.
Scott
dlink7
  • Moderator
  • 106 replies
PM has view on this issue. Most of the current networking effort has been focused on Azure.
  • 20 replies
Sorry maybe I was not clear in my original post. We have 2 AHV clusters in 2 different data centers we own. So it is not shipping to a cloud resource, rather between my 2 clusters.
dlink7
  • Moderator
  • 106 replies
You posted in the NC2 fourm. You would have to strentch the network between both clusters on-prem
  • 20 replies
My bad. Thanks for pointing that out. I can stretch the network via VXLan; however, it is unclear if I can share the managed network database of IP’s between the networks. So for example if I create a VM on Site A with a managed network and move it to Site B it should be fine as long as I have stretched the network. From what I understand of managed networks this VM will no longer be in the database so this IP will get handed out again. At this point I would have an IP conflict. I can move this to the correct forum as well if needed.
dlink7
  • Moderator
  • 106 replies
i am not expert but I believe you need to have 2 non overlapping dhcp pools, one on each cluster and it should work
