Hi, I have a trouble to enable Nutanix Calm when I try to deploy it, I checked NCC and everything run well but in Calm the Precheck failed: “ PC to 0005e2ce-d78a-2724-0000-00000000e308 host cluster health check is not OK. Please check if cluster is accessible from PC ”.
My Prism Central version is 5.20.4.5 LTS - Starter License
Please check that you have a Prism Element cluster registered with Prism Central. If you still continue facing the same issue, please open a support case.
