Is it possible to add more than one NIC as network client in a single deployment of Nutanix Files?
I am performing tests in which Nutanix Files would serve 03 different networks and during Files' deployment it is only possible to add 01 network client. However, this test will serve 02 other networks besides the one already configured.
@Moises S F Hi..  Yes.  Files supports Multi-Tenancy so you can deploy a FS-1_1, FS-1_2, FS-1_3 for one set of clients or VLAN and then a FS-2_1, FS-2_2, FS-2_3 for another set of VMs or VLAN.  Each FSVM cluster can have different replication RPOs as well.
Hope this helps.
Mike
