Hi there. I believe it was 5.18+ that the reverse proxy (apache) is no longer being used for cluster communication but something else. I can’t quite recall what it was called and where the logs can be found. Prior, I could access the httpd logs in the typical location for any http errors/faults but am not sure where to locate these now.
Reverse Proxy Question
Best answer by Michael.Manuele
Please let me if this was the directory/logs you were looking for.
Mike
