Hi All,
I’m sorry because couldn’t find related k/b on mixed nodes compatibility/requirements in details.
Just wondering current latest platform supported for mixed nodes with different OEM hardware model in same cluster? For example: Existing we have 3 x HPE DX360 in same cluster and would like expand with different hardware model/family such as Dell XC family/NX family or HPE higher model like DX380 in same cluster?
Appreciate it in advance.
John.
Hi John,
You can mix different models (360 wwith 380) and generations of the same vendor in one cluster, and even all flash nodes with hybrid nodes. But different vendors like DX and NX in same cluster is not supported.
Amr
Hi Amr,
Well noted with thanks. Appreciate it.
John
