LCM inventory process stuck at 5% | Nutanix Community
  • March 23, 2021
  • 4904 views
Hello!
I have an LCM inventory task that seem to be stuck in my cluster. It is stuck at 5% since 2 days ago. Please, help me to solve this issue.
The following command shows that there's not LCM process running:
$ acli task.list include_completed=false | grep lcm
Best answer by raaji
It is possible that LCM tasks get stuck and not progressing for a long time due to some issues.
  1. Check if any inventory operation is in progress from any of the working CVMs
ecli task.list include_completed=false operation_type_list=kLcmInventoryOperation
If there is any operation running, please contact Nutanix Support to manually remove the tasks and restart the inventory.
  • 69 replies
  • March 26, 2021
