I want to try FRAME with azure to see what it give “hope” azure native login is supported.
I created the enterprise application  , the secret etc..  the only step that i change is that i set the owner permission on the RG quite better than the subscription but i receive an ADAL error during  authentication ;  this is maybe because ADAL is depreciated ..  could you warn the support about it  ?
Hi Jean-Pol,
Are you an active Frame customer or just doing a Frame Trial? If you are an active customer - please open up a formal support ticket via My Nutanix → Support Portal. If you are doing a trial, can you please send this to frame-onboarding@nutanix.com and we will have someone assist.
