esxi 6.7 on Dell XC630-10? | Nutanix Community
  • February 7, 2020
  • 1610 views
Anyone know the highest supported ESXi version we can upgrade to on the Dell XC630-10?
Best answer by vkumarjr
@mwhite
Simple answer: ESXi 6.7 U2
Elaborate one below
You can look at the following link
https://portal.nutanix.com/#/page/compatibilitymatrix
This compatibility matrix shows the AOS, AHV, and hypervisor compatibility for Nutanix NX and SX Series platforms and SW-Only Models qualified by Nutanix (such as Cisco UCS, Dell PowerEdge, HPE ProLiant and others listed here).
However for XC platfrom we have following note
For other platforms not listed here, such as Dell XC, Lenovo HX, and others, please see your vendor documentation for compatibility.
However, liked to go an extra mile to share following details to you. The latest according to the following link is ESXi 6.7 U2
Dell EMC XC630 Series Hyper-Converged Appliance Support Matrix (Updated Feb 2020)
https://downloads.dell.com/manuals/all-products/esuprt_converged_infrastructure/esuprt_hyperconverged_systems/dell-xc630_support-matrix_en-us.pdf
HTH
  • 18 replies
  • February 10, 2020
@mwhite
Elaborate one below
HTH
