Prism Central Deployment Fails at Post-Deployment Step
  • February 26, 2026
  • 159 views
New Nutanix cluster
AOS 7.5, AHV 11.00 & Prism Central 7.5.0.5
when deploying it get to Post deployment steps and fails
i can ping the Prism Central vm
it gives the error
Encountered Exception in Post Deployment step timed out waiting for Prism gateway and aplos to come up
  • February 26, 2026
This can be lots of different things. Is the network setup correctly? Do you have installed a test virtual machine in the subnet/vlan to make sure networking is correct?
  • March 6, 2026
Experiencing the same error here. Also AOS 7.5. Did you find a fix?
