Upgrade Prism Central after AOS
  • February 11, 2021
  • 158 views
One of our customer upgraded AOS before prism central. What would be the impact of upgrading prism central after AOS considering it’s not the proper upgrade scenario ?
  • 2X3 nodes cluster :
  • AOS 5.15.4 LTS
  • ESXI 6.7U3 build 17167734
  • Prism Central 5.16
Best answer by Neel Kotak
Hello @tomazzzi
I would say upgrade the PC first and then let's monitor it
Neel
Neel Kotak
  • February 11, 2021
Hi @tomazzzi
If PE was upgraded before PC then chances of connection between PE and PC may break. They can try to upgrade PC for next and if any issues are reported then we need to investigate further.
  • February 11, 2021
Thx for your answer.
What is the safest for you :
try to upgrade PC anyway or unregister PC, delete the VM and install a new PC ?
Neel Kotak
  • February 11, 2021
Hello @tomazzzi
Neel
  • February 11, 2021
Ok i ll do that !
Thx a lot for your help.
Best,
Thomas
