Xi Leap vs Cloud Connect
  • July 14, 2020
  • 3276 views
Hello guy , hope you are all safe around the world !
I want to know what is the difference between xi leap and cloud connect ?
Thank you
Best answer by Neel Kotak
Hi @Abdoullah
In simple words, Xi LEAP is to connect On-prem Nutanix Cluster to Nutanix Xi Cloud Services as DR solutions.
Whereas Cloud Connect is to connect the On-prem Nutanix cluster with external Cloud Services like Amazone or Azure.
Here are the few guides to understand more
https://portal.nutanix.com/page/documents/details?targetId=Xi-Cloud-Services-Administration-Guide%3AXi-Cloud-Services-Administration-Guide
Nutanix Leap
https://portal.nutanix.com/page/documents/details?targetId=Xi-Leap-Admin-Guide%3AXi-Leap-Admin-Guide
Overview of Cloud Connect
Neel Kotak
  • July 14, 2020
Hi @Abdoullah
Nutanix Leap
  • July 14, 2020
thank you  @Neel Kotak for your help , i appreciate your quick answer
Neel Kotak
  • July 16, 2020
Hi @Abdoullah
If the answer is satisfactory to you then please close this thread by clicking “best answer” or let me know if anything else I can further help you with
A few weeks ago i was working implementing a cloud site  with azure cloud connect for backup purposes, and i had the same question about XI leap and cloud connect. Basically XI leap is a so much solid tool but its focused on Disaster recovery, you can use it for backup but you are going to waste money(cause XI leap its much more expensive) and you would lost its main functionality DraaS. With Cloud connect you only pay for storage(Bob or S3 object) wich is more flexible and cheaper.
