Mix Dell PowerEdge in Cluster with NX | Nutanix Community
Hello guys,
Is it possible to add Dell PowerEdge R640 or R730 hardware to a cluster with NX hardware?
Best answer by Neel Kotak
Hi @Moises S F
Nutanix does not support mixing Nutanix NX nodes in the same cluster with nodes from any other hardware vendor. However, you can manage separate clusters using the Prism webconsole regardless of the hardware type.
https://portal.nutanix.com/page/documents/details/?targetId=Hardware-Admin-Ref-AOS-v5_17%3Ahar-product-mixing-restrictions-r.html
Neel Kotak
  • 96 replies
  • June 25, 2020
Hi @Moises S F
  • 11 replies
  • September 18, 2020
Hi @Neel Kotak ,
From technical view, when expand node with different hardware vendor is possible can the node join to cluster?
  • 69 replies
  • September 21, 2020
Hi Hendra,
In a cluster with Nutanix hardware, we cannot add nodes from any other vendors. Currently not supported.
