Tuning Resources on Move VM
  • April 23, 2020
  • 2588 views
I hope this is an easy question.  Am I allowed to increase the VCPU and memory resources on the Move VM/Docker without issues?  I know hot-plug is disabled, so it’s in the reboot-world.  I found that we are pegging the CPUs out when we are queueing migrations, so I want to try to get some more throughput on it to take advantage of our 25Gb infrastructure.
Best answer by David Teague
Move does not have any hard limit on the resource configuration. So the RAM/ CPU configuration can be updated to a higher value. Also, the migration performance depends on the source (read) and target (write) performance and the network bandwidth.
David Teague
  • June 23, 2020
