Server Virtualization
How to schedule a VM power state with AHV
Adventurer
I will looking to migrate from VMware to AHV in the next few weeks.
As I understand it, it is not possible to schedule the state of a VM say for Shutdown or Power On, as you can do in VMware.
Is there a workaround and is this on the roadmap?
Tags (1)
Re: How to schedule a VM power state with AHV
Hi @ice
Can you elaborate more what exactly you meant by "schedule VM power state".
thanks
Artur
Artur Krzywdzinski
blog: www.vmwaremine.com
twitter: @artur_ka
Adventurer
Hi Artur,
So in vSphere right now there is an option to create throught the vCenter GUI a Scheduled Task (Change the power state of a VM, Clone a VM, Create a Vm etc).
The main use of Scheduled Tasks for me is to shutdown and then after a short delay, power a series of VMs back up.
Does AHV support such a feature?
Nope, it does not.
You will have two choices:
  1. Create PowerShell script/one-liner and put it into schedule on some windows box
  2. Create Bash script/one-liner and put it into CVM cron schedule
thanks
Artur Krzywdzinski
twitter: @artur_ka
