Scripts
Pulling AOS and Firmware levels?
SOLVED Go to solution
Adventurer
Question for you all. Is it possible to pull AOS and firmware levels using the cmdlets?
1 ACCEPTED SOLUTION
Accepted Solutions
Re: Pulling AOS and Firmware levels?
@mgalloway
You can capture the details using below commands.
1) Get-NTNXCluster -ExpandedOutput
* Version - AOS version
* Fullversion
* Nccversion
2) Get-NTNXHost -ExpandedOutput
biosVersion :
biosModel :
bmcVersion :
bmcModel :
hbaFirmwaresList :
@mgalloway
* Fullversion
* Nccversion
biosVersion :
biosModel :
bmcVersion :
bmcModel :
hbaFirmwaresList :
Adventurer
This is what I wsa looking for. Thank you
