Scripts
Powershell and VMNicSpecDTO
SOLVED Go to solution
Wayfarer
Looks like there may have been a change in doing:
New-NTNXObject -Name VMNicSpecDTO
in Powershell which is causing my script to fail adding a NIC to a VM.
When creating the object there is now an object (or array?) of 2 types, the first is AdapterType_Enum which is unexpected and breaks the script, the second one is VMNicSpecDTO which is what is actually required.  Forcing it to instead use $nicspec[1] and the script works as expected.
I'm using:
PowerCLI D:\> Get-NTNXCmdletsInfo
version 5.1
BuildVersion 2.0-release5.1-dev-28022017
RestAPIVersion v1
example:
PowerCLI D:\> $nicSpec = New-NTNXObject -Name VMNicSpecDTO
PowerCLI D:\> $nicSpec.networkuuid = "d0ebba66-bb01-4b72-85f6-708156358ee3"
The property 'networkuuid' cannot be found on this object. Verify that the property exists and can be set.
At line:1 char:1
+ $nicSpec.networkuuid = "d0ebba66-bb01-4b72-85f6-708156358ee3"
+ CategoryInfo : InvalidOperation: (Smiley Happy [], RuntimeException
+ FullyQualifiedErrorId : PropertyAssignmentException PowerCLI D:\> $nicSpec E1000 macAddress : networkUuid : model : requestedIpAddress : requestIp : adapterType : portId :
PowerCLI D:\> $nicSpec[0].gettype()
IsPublic IsSerial Name BaseType
True True AdapterType_Enum System.Enum
PowerCLI D:\> $nicSpec[1].gettype()
True False VMNicSpecDTO System.Object
PowerCLI D:\> $nicSpec[1].networkuuid = "d0ebba66-bb01-4b72-85f6-708156358ee3"
PowerCLI D:\> Add-NTNXVMNIC -Vmid $AHVVM -SpecList $nicSpec -Servers $DestAHVClusterName
Add-NTNXVMNIC : Cannot bind parameter 'SpecList'. Cannot convert value "E1000" to type "Nutanix.Prism.DTO.Acropolis.VMNicSpecDTO". Error: "Invalid cast from 'Nutanix.Prism.DTO.Acropolis.AdapterType_Enum' to 'Nutanix.Prism.DTO.Acropolis.VMNicSpecDTO'."
At line:1 char:38
+ Add-NTNXVMNIC -Vmid $AHVVM -SpecList $nicSpec -Servers $DestAHVClusterName
+ CategoryInfo : InvalidArgument: (Smiley Happy [Add-NTNXVMNIC], ParameterBindingException
+ FullyQualifiedErrorId : CannotConvertArgumentNoMessage,Nutanix.Prism.PS.Cmds.Acropolis.AddVMNIC
PowerCLI D:\> Add-NTNXVMNIC -Vmid $AHVVM -SpecList $nicSpec[1] -Servers $DestAHVClusterName
taskUuid
00d49b8e-cf15-4afc-9c00-ac073f800499
1 ACCEPTED SOLUTION
Accepted Solutions
Re: Powershell and VMNicSpecDTO
@MattDonovan
This issue is fixed in AOS - 5.1.1 / CMDlets - 2.1.1 version.
Key Value
version 5.1.1
BuildVersion 2.1.1-release5.1.1-dev-05302017
RestAPIVersion v1
PS C:\Windows> $new = New-NTNXObject -Name VMNicSpecDTO
PS C:\Windows> $new
macAddress :
networkUuid :
model :
ipAddress :
requestIp :
adapterType :
portId :
PS C:\Windows> $new[0]
macAddress :
networkUuid :
model :
ipAddress :
requestIp :
adapterType :
portId :
Tags (1)
This is a bug on our side. Somehow while creating the object for VmNicDTO it is capturing the enum in the dto.
The workaround for this would be to use
$nic[1].networkUuid = $network.uuid
However the workaround does seem to allow defining $nic variable, but then it breaks at Add-NTNXVMNIC
Add-NTNXVMNIC -Vmid $vmId -speclist $nic
At line:1 char:37
+ Add-NTNXVMNIC -Vmid $vmId -speclist $nic
So you need
Add-NTNXVMNIC -Vmid $vmId -speclist $nic[1]
@MattDonovan
Key Value
version 5.1.1
RestAPIVersion v1
PS C:\Windows> $new
macAddress :
networkUuid :
model :
ipAddress :
requestIp :
adapterType :
portId :
macAddress :
networkUuid :
model :
ipAddress :
requestIp :
adapterType :
portId :
Tags (1)
Wayfarer
great, thanks, will upgrade soon.
also the guestOperatingSystem property is blank for all my VMs, even if NGT is running, is that expected?
PowerCLI D:\> Get-NTNXVM -SearchString m30
vmId : 00052165-4685-4721-6567-a0369f750aa8::14de3922-3f74-4543-8ad7-c76aaacd05ca uuid : 14de3922-3f74-4543-8ad7-c76aaacd05ca powerState : on vmName : M30 guestOperatingSystem : ipAddresses : {192.168.21.130} hypervisorType : kKvm
<snip>
@MattDonovan
Currently "Guest OS is applicable only for ESX Vms".
Adventurer
We worked around this issue by inspecting the New-NTNXObject  object and looking for the correct index location.
`$nicSpec = New-NTNXObject -Name VMNicSpecDTO`
On 5.0 `$nicSpec` has two items `[AdapterType_Enum, VMNicSpecDTO]`
On 5.1 `$nicSpec` has one item `[VMNicSpecDTO]`
By looking for the index location of the element of name 'VMNicSpecDTO' powershell supports all version (5.0, 5.1, 5.1.1)
        # Nutanix Powershell Cmdlet 5.0, $nicSpec is array of length 2 [AdapterType_Enum, VMNicSpecDTO]
        # Nutanix Powershell Cmdlet 5.1 $nicSpec is array of length 1 [VMNicSpecDTO]
        $nicSpecDTOCounter = 0
        $nicSpec | % {$nicSpecCounter = 0}{
          if ($_.gettype().Name -eq 'VMNicSpecDTO') {
            $nicSpecIndex = $nicSpecCounter
            $nicSpecDTOCounter = $nicSpecDTOCounter + 1
          $nicSpecCounter++
You can then refer to the $nicSpec variable like so
Instead of hard coding `$nicSpec[1]`, you can reference the variable `$nicSpec[$nicSpecIndex]`
Wayfarer
I am running 2017.02.23 version
Is this issue fixed on CE version too?
Wondering if it is fixed on  ce-2017.07.20.
