Product Ideas
2 node cluster - low cost robo
Moderator Moderator
Moderator
Re: 2 node cluster - low cost robo
@dbauer1 - Minimum is still 3 nodes as of today, and the exact requirements for a future 2 node solution have not been released yet. Just wanted to say this as I want to make sure we dont improperly set expectations that a two node 1050 cluster will ever work, as it simply just isn't a feature yet.
Jon Kohler | Principal Architect, Nutanix | Nutanix NPX #003, VCDX #116 | @JonKohler
Please Kudos if useful!
Voyager
Has there been any update to this request on the CE platform?
Guardian
The mentioned 1,2,3.....  node clusters at .NEXT.  I'm not 100% sure when it happens but it was mentioned.
Voyager
I heard the same, didn't know if that included CE or not.
Guardian
@Jon.  Jon, you probably know better than all of us.
Wayfarer
...and it would be great if Jon would finally come up with an answer: 1- and 2-node clusters were already promised on the .NEXT in Vienna.
Any Update on 1- 2- node clusters?
Scout
Hi Jon,
I would actually support Brian idea with 2 node cluster for low cost robo.
I recently attend Dell-EMC MasterClass and Nutanix 1-day bootcamp, and discuss this idea with presenter. Both said it's not something Nutanix consider at this moment... citing the 3-node cluster cost still going to be better than traditional single node.  IF the robo only run 1 or 2 VM, the extra capacity just a waste of resource. Maybe the 3rd node (witness) can be linked back to (utilise) HQ cluster... although the latency might be an issue.
Cheers,
Tonij
mld
Wayfarer
My company would be interested by a low cost Robo solution.
Small remote sites have one or two rooms. They just need of a few VM but a replication to be able to restart quickly.
The only alternative I found is to setup 2 ESXi with local disks and use vSphere replication between the two nodes.
Regards
MLD
What is the budget? the SX1000 series for robo can be affordable, even with 3 node cluster.
mld wrote:
Regards
MLD
