Prism
How to rename CVM Container?
SOLVED Go to solution
Adventurer
Is there a way to rename the CVM Container without rebuilding the container? The vendor who recently re-installed the Nutanix Block didn't follow the directions and named the container incorrectly.
The container has 4 Virtual Servers running on them and I would like to preserve these systems without the need of rebuilding them.
Could I place each VM in the Local NTNX-local-ds (SSD) datestore since the 50GB available is larger than each VM?
Then Destroy the Container and Recreate it?
David
1 ACCEPTED SOLUTION
Accepted Solutions
Guardian
Re: How to rename CVM Container?
You could build a second container with the correct naming, mount it to the hosts and then do a storage vmotion to the second container.  After all the VMs are moved you then delete the original container when its unmounted.  Definitely stay away from the local datastore.
I would do the storage vmotion's in the off-hours though.  Our early experience with storage vmotions between data storage was that it caused increased latency to all the vm's in the cluster.
Guardian
Adventurer
patrbng,
Thanks for the idea.. didn't even think of creating another Container. It woked like a charm. The system is not in production and the storage vMotion of the VM's went fairly quickly.
David
Guardian
Great news.  Hopefully you'll have great success with your Nutanix solution!
Guardian
@hatchda in order to rename container without creating new one you can do as follows
1. power off all VM's on the container
2. remove VM's from vsphere inventory via vsphere client
3. unmount the container via Prism
4. rename the container via ncli
    ncli> container ls
    ncli> container edit id=13361 new-name=new-container-name
5. refresh the prism
6. mount the container to all ESXi hosts via Prism
7. verify renamed container via vsphere client
8. right click on vmx file and add to inventory for all VM's affected
