Nutanix Platform Professional (NPP)
how to be trained and have a certificate Nutanix ?
Apprentice
Moderator Moderator
Moderator
Re: how to be trained and have a certificate Nutanix ?
Do you work for a Nutanix partner? If so, you can work with the Nutanix Partner Portal to do the Technical/Sales Academy training.
If you are on the customer side, you can log on to portal.nutanix.com and click on Training for the self paced class. Also, we have instructor led, paid classes available around the globe, and even on site if you prefer
Jon Kohler | Technical Director, Engineering, Nutanix | Nutanix NPX #003, VCDX #116 | @JonKohler
Please Kudos if useful!
Kub
Wayfarer
   I don't work for a partner or I am representing a customer. I want to get trained and earn certification. When I try to connect poral.nutanix.com, it is asking for a service tag, which I don't have.
   Question : How do we get to self paced instruction material ? Appreciate your help.
Kub
Wayfarer
To be clear: Neither I work for a partner nor I am representing a customer. I just want to learn the Nutanix platform, and earn certification.
Moderator Moderator
Moderator
You need to be either a customer or a partner to get access to the NPP course material.
That doesn't mean you can't learn a TON about Nutanix.
We've got two very active YouTube channels with a bunch of great content. We also have the Nutanix bible, which has technical detail on almost everything you'd want to know about Nutanix.
If you go through the Nutanix Bible and our YouTube content, you'll be very knowledgable about our product.
From there, you can actually use our product on your own equipment to try it out. We've got Nutanix Community Edition, which you can run on bare metal OR you can run as a nested vSphere instances OR you can run it in the cloud on Ravello (which should be a familar name to you specifically) OR you can run it ondemand through Test Drive, an online portal which gives you a small Nutanix environment for a few hours to play around with (this is also backed by Ravello).
Nutanix Bible: http://nutanixbible.com/
Nutanix company YouTube: https://www.youtube.com/user/Nutanix
Nutanix Education YouTube: https://www.youtube.com/channel/UCJupSMWQRKQTvkb2CfkW0Eg
Nutanix Community Edition: http://www.nutanix.com/products/community-edition/
Nutanix Test Drive: http://www.nutanix.com/testdrive/
Nutanix Test Drive Getting Started Guide: http://go.nutanix.com/rs/031-GVQ-112/images/GettingStartedGuideTestDrive.pdf
